Thread: K&N Airfilter carb readjustment
    Member sk8erpope's Avatar
    Sep 2020
    Heidelberg, Germany
    I replaced the stock airfilter on my 1967 2.0 with a set of K&N filters.
    Does the carburetor have to be readjusted for this or even jets exchanged?
    Thanx for your help.
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Ideally yes, do you have WBO2 / Lambda thread in the exhaust?
    Otherwise on a rolling road with a stationery exhaust analyzer.
    Sep 2020
    Heidelberg, Germany
    Quote Originally Posted by uai View Post
    Unfortunately I don't have either of them
    Did the idle speed change? If not you probably don't need anything, maybe a readjustment of the idle mixture screws. While the dyno test would be nice it may just be overkill.
    Sep 2020
    Heidelberg, Germany
    The idle speed doesn't change, but I runs a bit rough and unequally when accelerating.
    Jan 2011
    Horb a.N. Germany
    You could just increase the idle jets and/or the mains to the next size but in the end it's easier and safer to have the mixture checked.
    You could give siggi a call he's got a rolling road and is not too far from you.
    But I don't know if he has all jets on stock.
