Results 1 to 9 of 9
Thread: Installing German sound dampening pad
    Senior Member rgupta250's Avatar
    Jul 2020
    Orange County, CA
    Hi Everyone:
    I am undergoing a bare metal restoration on my 71T and need some help with the installation of the sound dampening pads on the floor boards. I was able to source German sound dampening pads with the hex pattern (see picture below) but there is no adhesive on the underside. I believe the best solution will be a product which can be sprayed on so that there is even coverage and it does not create high and low spots. What product should I use?
    Best,
    Ravi
    1971 911T/2.45 engine spec Coupe / Gold Metallic on Black
    1995 911 C2 / Guards Red on Cashmere Beige (Sold)
    Aug 2017
    el sobrante ca.
    i do not know about 1971 or the material that you are showing.
    in 1968 Porsche used a 3mm thick tar matt with smooth felt on top.
    It was melted onto the body with a heat gun or torch...
    your product needs to be examined to determine if it should be apiyed that way
    Jul 2020
    Orange County, CA
    Hi Bob,
    The material in the photo is a thick tar-like mat about 3mm thick. It does not have any felt on it but from all the original 1971 floor boards I have seen there was no felt on the sound dampening pads.
    best,
    Ravi
    Aug 2017
    el sobrante ca.
    good.... actually, the surface with the squares is the "felt" side.... Now if you have what i think you have it will melt with a very hot heat gun or propane torch. this will stick it to the floor.
    The tar cools very fast. so heat it in small areas and then press it into place. it will conform to the "ribs" in the floor.
    were did you source the material and how long and wide is it..
    Jul 2020
    Orange County, CA
    It’s actually a BMW part and I figured German OEM is close enough to the original material. Each panel measures 1160mm x 700mm. You need three panels to cover the entire driver and passenger floor board areas.
    Aug 2017
    el sobrante ca.
    just my opinion. i think it would look very good in your 1971.
    Nov 2010
    Darien, CT
    I would use 3m general purpose trim adhesive. Pretty good stuff and used it numerous times for different interior work. Just be sure to follow the instructions and spray both sides until tacky.
    https://www.3m.com/3M/en_US/p/d/b40069451/
    69 911S #1379
    65 356 SC #130757
    May 2013
    Victoria BC Canada
    Quote Originally Posted by rgupta250 View Post
    Hi Ravi, would you please provide the BMW part number.
    Regarding installation, you might look into primers that are used for bitumen based waterproofing membranes for buildings (spray on and brush on primers are available), to coat floor pan before installing sound deadener pads. Just a thought.
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    There is a stamp on the damping pad - FAIST -
    this is the producer:
    https://www.faist.de/?gclid=EAIaIQob...SAAEgLB8fD_BwE
    br
    haul
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
