Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Famous 911 Door Thud
  1. #11
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    One will never be able to get a 911 door closing to sound like a 356. Now that is a sweet sound!
    Sorry, I couldn't help myself.
    Jim
    Jim
    I must admit that I used to own an original 1956 Marc SL 190 and the doors sounded so 'sweet' I used to open and close them just for the hell of it.
    Rightoh back to the 911 PING
    Mark
  2. #12
    Member Bahman's Avatar
    Jan 2021
    Greensboro NC
    You may want to wiggle the latch slightly (trial and error) to see if it would help getting that desired sound. those white plastic pieces in the latch move and serve as alignment and movement control buffers, and a very slight (1mm or less) tweaking can help imrprove door closing 9somoothness) and making that pleasant sound.
    My '72E Targa had that pleasant sound on both doors. Just for the heck of it, I replaced the driver-side latch with a new one, and it destroyed that pleasant sound. Fortunately, I had saved and marked the old latch; reverted to it, and all is well now. Just my 2 cents worth.
    1972 911E Targa, Mostly Original
    2002 Porsche 996 C4 Cabriolet
    2005 Turbo-converted MINI Cooper S
  3. #13
    Feb 2020
    NW CT
    Quote Originally Posted by NZVW View Post
    The ""PING"" harmonic is definitely a sound that is more prevalent on original cars.
    I saw a couple of long hoods last weekend both of which had door off restorations and neither had the piano tuning fork ""PING"".
    I agree with this, though I have also had the ping restored! One of my coupe doors never pinged, and one of my requests for the winter work was to have the ping restored. Low and behold, the ping has been restored. I'd also note that sometimes the rubber seals can interfere a little with the door closing, and watched an expert take a razor blade to shave off no more than a millimeter or two from mine, and it improved the shut immeasurably (I had a ping, but the door would bounce a little on occasion). Thus, you can fiddle a bit with the latch, and the rubber...but the ping is recoverable. And like many things, these cars shouldn't be driven without their melodic ping. Well...they should be driven regardless, but the ping is right up there with the stink as part of the experience.
    MBR #3926
    '71 911 T Targa "Rick White"
    '71 911 E "Karen"
    '70 S/T
    '16 CD
    '10 E61 "Vomit Comet"
  4. #14
    Aug 2010
    Colorado
    Could it be that the restored doors have sound reducing pads installed? That would muffle the ping.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
  5. #15
    Apr 2011
    N.Calif., south of SF
    Jay, no expert here but I noticed that both my doors "jumped" a little when opening with the door handle. They sounded pretty good but often a bit hard to close first time. I found the correct star tool to adjust the striker plate.
    With a bit of experimenting I found both doors unadjusted did the jump. Once adjusted, both closed really well and the ping seemed louder than ever.
    I suggest marking their location in the door jam with a lead or grease pencil to track the changes. And yes, the white plastic pieces do fail.
    Hope this helps.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  6. #16
    Jun 2012
    London, Ontario, Canada
    I recently got all my locks rekeyed properly. As part of that I removed both front door panels to get at the handles and locks and lubed everything I could, including the window mechanisms. The right side door didn’t quite ping the way the driver’s door did, but after lubing everything and reassembling, they now match nicely. There is a rubber standoff that supports the rod that goes from the handle/lock to the interior push/pull black locking thingy that you use to lock/unlock the car from the interior. The passenger one was long gone. The rod is likely the source of the ping and if the standoff has fallen apart, that tends to mute the sound. The part is still available from Porsche.
    Ravi
    Early 911S Registry # 2395
  7. #17
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    I always assumed the source of the ping was a spring vibrating?
    Brent
    '70 911S
    '68 TR250
  8. #18
    The spring makes the noise, if you give the latch mechanism a good preservation lube job, they won’t ping like when they are dry.
  9. #19
    Thanks for all the suggestions to adjust the striker plate. Sure enough. Just a mm or two, and the door opens and closes much nicer - and there is a distinct ping now.
  10. #20
    Aug 2017
    el sobrante ca.
    if you look at the workshop manual it shows that the receiver on the lock post must be vertical with torpedo level.
    then it also "should" line up the points with the bumps on the lock post
    you close the door just enough that you can peek into see how the door male part is entering the female catch.
    the mail piece should enter initially without touching the female part until it touches the back part. that is what activates the closure.
