Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Famous 911 Door Thud
  1. #21
    What is the “torpedo”?
  2. #22
    Aug 2017
    el sobrante ca.
    torpedo level is small handheld level
    about 8' long 1/12" wide
  3. #23
    Quote Originally Posted by bob joyce View Post
    if you look at the workshop manual it shows that the receiver on the lock post must be vertical with torpedo level.
    then it also "should" line up the points with the bumps on the lock post
    you close the door just enough that you can peek into see how the door male part is entering the female catch.
    the mail piece should enter initially without touching the female part until it touches the back part. that is what activates the closure.
    That's dirty.
