Results 1 to 7 of 7
Thread: Spark plug fouling in a 2.7l RS spec engine
    I’m having trouble keeping the Bosch WR5DC+ plugs in my 2.7l RS spec engine from fouling. Except for Weber carbs, ported heads and cams with more aggressive acceleration ramps, the engine is essentially built to ‘73 Carerra RS specs.
    This’s in the 914/6 I bought in 2020. Before shipment to North Carolina, I had it serviced at a well known, highly respected race shop. The only carb related work on the invoice read “Sync carbs and adjust idle and mixture“ for labor; nothing wrt parts.
    My operating conditions are not the best … so far confined mostly to stop & go driving in moderate traffic with speed limits of 45mph half the time. Despite the CDI, keeping the revs to 2000 at red lights and above 3000 while moving, the plugs are fouled for the second time in only about 300 miles since receiving the car. Under these conditions, and in today’s environment with cell phone cameras everywhere, etc., it’s impossible to do enough “Italian tune-ups” to keep the plugs clean ;-)
    How likely is it the Webers are already out of tune? (Not many miles, but 2 years later.)
    I’m curious what experiences others with similar spec engines may have with spark plug heat ranges … what you’re using vs how the car’s driven?
    I’m thinking the aggressive cam profiles, including the faster acceleration ramps, are playing a role, plan to try incrementally hotter plugs a step at a time until I get the fouling under control.
    Here’s a Bosch cross reference chart for heat ranges of popular brands:
    Regards,
    Bob
    Bob Schaefer
    ‘67 911S Canary/Lemon yellow, sunroof coupe produced w/100L tank. Until determined otherwise, 306943S appears to be 1 of 1, and among the earliest 911’s with a 100L tank. The 911’s initial participation in a competitive event, the 1965 Monte Carlo Rally, was fitted with a 100L tank (#300055). Seeking additional info on earliest 100L tank fitments to 911’s.
    ‘70 914/6 (2.7l RS spec engine, but searching for 6404915 original)
    That is a liberal interpretation of RS specs. Different cams, different porting and on carbs.
    I run BPR7EIX in my MFI 2.7 without any fouling. I don't know why you keep the revs above 2k at stops but 3k sounds low enough to qualify as lugging.
    I am not a fan of Bosch plugs.
    Same as David, I have a carbed 2.0 and two 2.4's with MFI. I run NGK BPR7ES in all three, no plug fouling irregardless of idling time. Your problem may not be spark plug related.
    Apr 2011
    N.Calif., south of SF
    Ed- curious what are you gapping the NGK BPR7ES at?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    The stock gap. I didn't see you in Utah last week?
    Apr 2011
    No Ed, really wanted to bust bugs in Utah with you all.
    Our country store had several employees come down with COVID. I canceled to help fill in. In the end we closed and I could have. Hope you all had a great time.
    Jeff
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
