I've been trying to get my car close before taking it in for alignment. I have some Eiback (front 200 pounds) and Hyperco (rear 250 pounds) springs. Why different companies? Supply issues. My car was just on a body shop rack and all pickup points are good. I've been frustrated. When I have the car at 25 inches front and 24.5 in the rear at the top of the wheel wells the threads on the coil overs are different side to side both front and rear. Like over an inch at the threads. I've measured the coils and each coil varies .3 to .4 mm on the same coil. I'm about to take them apart and have the springs tested. They appear to be not even close side to side. This makes camber and toe adjustment difficult.
Has anyone run into this issue?
