Results 1 to 1 of 1
Thread: Rebuilt 3.2 engine for sale
    Dec 2010
    Wilmington, DE
    We just rebuilt this engine. Ran it for 200 miles in a Carrera (break in/tuning) and pulled it to clean it back up for sale. A Peter Dawe trained tech with maybe a hundred rebuilds under his belt did the work with all the right parts. Then Kevin Dawe did the final tuning and says it runs strong and sounds great. Includes Motronic harness and computer. $27,995. Email - Mark@MarkEpstein.net to purchase.
    Crank polished
    Rods reconditioned
    ARP rod bolts new main bearings
    Clevite ceramic coated rod bearings
    New intermediate shaft bearings
    Reconditioned oil pump
    New iswis timing chains
    All new timing chain ramps
    New canyon head studs
    Piston &Cylinders inspected and new rings
    Cylinder heads have new valve job and surfaced. Guide checked and replaced as needed
    All new seals and gaskets
    Rebuilt injectors
    Fuel injection was completely disassembled and parts replaced as needed
    New cylinder head temp sensor
    Stock heat exchangers thoroughly cleaned
    Stock muffler modified with two out in the center.
    All engine components were ultrasonically cleaned. Oil cooler also was pressure tested.
    A part isn't purchased until paid.
    The 9 Store LLC.
