Thread: Why does my fuel gauge fog up
    What the title says, any ideas please?
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Apr 2004
    35,000 ft
    There are theories that it’s the proximity to the door window that ages the rubber seal between the glass and the body of the fuel gauge. Causes the seal to dry out and allow moisture to build up in the gauge housing.
    Some say, take apart the gauge and install a small desiccant cartridge, often found in a bottle of aspirin or other pills. To me, that’s a band aid fix. Not a cure. Best bet it to clean the glass, replace the rubber seals and make the gauge air tight again.
    Also some theories that glass isn’t perfectly clean is more likely to fog up.
    I’d be very curious if the clock on your RHd fogs up. Or maybe it’s still the fuel gauge.
    The other theory is that the gauges with removable gauge mechanisms (gas, oil temp, oil pressure and oil level. Are more susceptible to fogging because there are more places to air and moisture to enter.
    Atlanta, GA
    My 73S does the same thing. Then drys out.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Sweden
    I picked together a nice working clock from one nice looking and one working.
    The working one had no paint on the inside of the housing, it was just plated on the inside. The clock had a lot of micro-dust (white rust) from the corroded plating on the faceplate and the glass looked faded.
    The nice looking one had paint on the inside of the housing and everything looked like it was new.
    Light Yellow -74
    @lagteknik
    Quote Originally Posted by blucille View Post
    I think the theory does not hold up as clock is fine in my car
    Clyde Boyer
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Had the same problem here today. Drove out of the cold garage into the sun and the tank gauge fog up
    Mar 2017
    Orange County, CA & Tucson, AZ
    same thing happens in my '82 SC
    and it is weird that it is just the fuel gauge that does this
    Bill
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    Aug 2020
    Shawnee, OK
    A combination of a failed air seal, temperature, altitude, humidity and cycling of these factors is the problem. The bad result is fogging, but a worse result is corrosion. Once the seal fails and temperature rises, air heats up and escapes the gage. When the temperature falls, outside air gets pulled into the gage and if the humidity is high, this air is full of water. When the temperature is below the dew point, then the moisture condenses, makes water droplets, thus fogging. When the gage heats back up, the fog can evaporate. This cycling continues with temperature, humidity and pressure changes which can either result in no fogging, intermittent fogging or at the extreme to the gage filling with water.
    This is a common problem for aero-space particularly in portions of the aircraft that are not pressurized. On critical components and military aircraft it is pretty common(and very expensive)to use a vacuum to coat the electronics and interior with paralene and use drain holes to solve this problem. On a less critical scale, the same problem occurs on double pane windows when the seal fails, then condensation starts showing up between the panes.
    Make sure the seals are good on the gages, live in the desert or a bag of desiccant if all else fails! If it is fogging, it will be corroding.
