Results 1 to 1 of 1
Thread: Torsion tube / axle tranverse tube on a 1969????
    Aug 2011
    Lake Geneva / Switzerland
    Hello,
    I could need some help during a repair of a 911E Targa from 1969. Unfortunately, the rear axle transverse tube ends are heavily rusted and the tube has to be repaired with a sleeve. During the repair the bodyshop is facing some uncertainty. Actually, the chassis is fixed on a Celette, but it seems, that there is weird situation on my Targa from 1969. The dimensions of LWB is 1079mm (+ - 0.5mm)…. Would it be the same for SWB or the transsition year?
    Does anybody know the correct tube length of a 1969 Targa?
    Actaully it doesn't look totally right for me....
    The repair should be done in this way. We will use the shorter sleeve....
    The Targa on the Celette with the removed torsion tube fixture....
    Name:  Celette Aufbau.jpg
    The dimension from the Porsche manual..... LWB after 1970
