Results 1 to 10 of 17
Thread: rear fuse panel
    Jun 2011
    Bellingham, WA
    rear fuse panel
    I have a 72 911T. The sticker on the cover of the engine fuse cover is missing. from top to bottom, what is the fuse amperage and what does each fuse control. FWIW, I have the single stage rear defogger if that makes a difference
    I don't believe there was a sticker, the fuse info is embedded on the inside of the cover if memory serves me right.
    Jun 2012
    London, Ontario, Canada
    If mounted correctly, the engine fusebox should be in the order of position 3,2,1 from top to bottom.
    Position 3 should have a black/red wire and a red wire on either side. It is an 25 Amp fuse. The red (a thicker red wire than the same side one that goes to fuse position 1) comes from the starter motor and is always live. The red/black goes to rear window defogger relay.
    Position 2 should have a red/white on one side. The other side is bridged to position 1. It is an 8 amp fuse. The red/white goes to the cold start valve relay (for MFI) and the speed relay for the anti-backfire function for MFI.
    Position 1 should have a red wire coming to it and nothing leaving. This is a 5 amp fuse (if anything is actually installed) and is supplied by switched power from the ignition switch via the 10 fuse panel in the frunk. Not sure what accessory it is used for. I've usually seen no fuse in this position.
    Ravi
    Early 911S Registry # 2395
    Jun 2003
    Toronto
    Position 1 is for the Sportomatic switch, terminated with a blue/yellow wire on 70/71’s.
    Quote Originally Posted by 72t4tom View Post
    Here it is
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Jun 2012
    Actually, I don't believe there was a cover for the engine fuses in 72/73. The big plastic cover with the two knurled knobs over the whole rear console was all that was provided. I think I asked about this once in my build thread.
    Ravi
    Yes and that was stuck on the inside of the plastic cover but suspect it didn't stay there for long as only ever seen one original which is what my copy was made from
    Clyde Boyer
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Clyde,
    I wonder how many of us have run off to check
    Mark
    Plenty I suspect but unlikely that anyone has found one intact!!!
    Clyde Boyer
    Ravi
    When was your S built Ravi?
    Clyde Boyer
