Results 1 to 2 of 2
Thread: Throttle Body
    Dec 2013
    Connecticut/Florida
    Throttle Body
    Found this when I removed my TB from my 1973S....I assume it can't be repaired?
    1971 911S Coupe - Gemini Blue
    Jun 2012
    London, Ontario, Canada
    Common. I have one like that but no piece to epoxy back on. You can epoxy a sleeve and put a good repair together. Functionally it doesn't matter, the main piece is more than enough to hold it down using the stock washer and nut.
    Ravi
    Early 911S Registry # 2395
