Results 1 to 7 of 7
Thread: WTB: Velocity Stacks
    Aug 2010
    Colorado
    Looking for a set of 6 46 or 48 mm velocity stacks. Here is a picture of the measurements in mm. RSR sized plumbing, but using a stock metal air cleaner. Maybe a set from some Weber 46’s.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Aug 2010
    Colorado
    https://www.ebay.com/itm/332300372093
    I'm going to try these.
    I'll blend the two parts 48 mm to 50 mm. That will only be 1 mm all the way around. I bought the middle 50 mm tall ones.
    You can find these and the 40's with the 65 mm stud holes at danST Engineering.
    www.reSeeWorks.com
    Feb 2003
    Los Angeles
    Hi Chris,
    I have a set of velocity stacks for 46 mm Webers.
    The ID bore = 46 mm
    Send me your email for photos. Your PM box is full.
    Bert
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Aug 2010
    Colorado
    Darn. I just bought the 50's.
    www.reSeeWorks.com
    Feb 2003
    Los Angeles
    The mount studs measure 65 mm center to center.
    Let me know if you change your mind.
    Bert Jayasekera
    R Gruppe #167
    Chris, clean out your messages.
    registry# 1283
    Aug 2010
    Colorado
    Oops.
    Geeez. I only had 350+ saved inbound and 500ish outbound. They are thinned out now.
    Sorry.
    Lars,
    I was just talking to Steven Rowe at his shop. I brought up your name and talked about all your MFI stuff. I should have called you.
    Oops again.
    www.reSeeWorks.com
