Thread: Copper air conditioner O-rings
    Junior Member
    Dec 2016
    Joplin, Mo
    Hello - I’m re-installing the air conditioner on my 73 911 E
    Watching UTUBE videos I see that Porsche uses a form fitted copper o-ring to help seat the fittings going to the compressor and all the other refrigerant lines.
    Does anyone know if the copper rings are still available?
    I looked at Stodard website and a couple others, however no luck.
    Thank you for any help.
    Best over here. Good luck with your search.
    Peter Kane
    '72 911S Targa
    yes they are, try an a/c supply place
    I inherited a box with a wide variety of copper o ring / gaskets. I separated them and have listed them for sale on the Samba. Here is an example of one size of the many I have inherited. Not at all sure if these represent the "O ring" you are looking for but thought I would throw my hat in the ring.
    https://www.thesamba.com/vw/classifi...php?id=2542307
    Henry
    BMW also uses the same style as well and a lot of guys are putting newer style systems in so some of the E9 guys may have some of the older style copper rings available I am assuming that they are the conical shaped ones Try on the E9 forum
    Thanks, Rick
    Mercedes also used the copper cone sealing washers in the cars of the '60s & '70s you could look over there also
