Thread: Where does this go?
    Aug 2020
    Shawnee, OK
    Where does this go?
    Found this and a guessing it goes in the engine area.
    Any ideas?
    Looks like it might be the distributor hold down.
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Aug 2020
    Shawnee, OK
    999-511-046-03 is the part number for the distributor clamp, but it has a split with a bolt used to set the timing. Maybe this could be a spacer that could be used below the clamp, but the PET does not show any spacer. The large hole is 25mm.
    It’s to hook your engine to.
    It should be on top of the case near the breather.
    Richard
    Engine hanger.
    Aug 2020
    Shawnee, OK
    Perfect! Glad it was not something that was supposed to be inside the engine. Glen49 that is a pretty engine, what are the holes in the lower valve cover? Maybe to set the cam timing?
    Quote Originally Posted by 1969911T View Post
    Twin plug.
    R
    Apr 2011
    N.Calif., south of SF
    Richard - nice job
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
