Results 1 to 10 of 11
Thread: Using 2.2 pistons with 2.4 crank & rods ?
    Guys
    Decided to change to 2.4 crank & rods but already have the 2.2 pistons …
    Pistons are CP 87.5x9.5x 2.2r (66stroke)
    Cylinders are LN 87.5
    Was advised that the piston skirts need trimmed by +- 1mm to clear at crank ?
    Also will the 2.4 rods mount to the 2.2 pistons or mods needed ?
    Thanks for comments & recommendations
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Nov 2003
    Santa Monica CA
    with cylinders at 87.5 from LN ; I assume you had to enlarge the spigots on the case for those cylinders right?
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Yes spigots were enlarged….
    Any thoughts on the 2.2 pistons mounting to the 2.4 rods ?
    Seems the CR will be over 10 …shooting for around 9.5 what’s recommended?
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Quote Originally Posted by raspy2point2 View Post
    Please correct me if I am wrong, but aren't the 87.5 LN Nickies the largest LN cylinder that will sleep fit the stock 2.2 case spigots? It was my thought that the spigots did not need to be enlarged?
    Thanks!
    Aug 2005
    Bucks Co., PA, USA
    Quote Originally Posted by Alaskan911 View Post
    That was my understanding per LN and the reason why I went with them for my build (87.5 x 66 = 2380cc).
    ESR #1474
    Nov 2003
    Santa Monica CA
    And so do they fit teenchy? My understanding is the largest without enlarging the spigots is 86 mm. and that is pushing it. You end up with very thin cylinder walls and risk warping the walls.
    Jul 2015
    Ohio
    Everything will work just fine with a small corner taken off of the piston at the bottom corners on the skirt. I built a 2.4 engine using this combo a few years ago and I test fitted the rod with a piston on the crank outside of the case. You will see where the piston hits on the crank throws. Grind to get the desired clearance. Then rebalance everything.
    If you want to lower the CR just add some shims under the cylinders.
    Good luck with the build. It's a great combination that works really well.
    Aug 2005
    Bucks Co., PA, USA
    Yes. The case only required a line bore in addition to the oil bypass and piston squirter mods (it's a '70T case).
    ESR #1474
    After much going back and forth on pistons and understanding they will work
    have decided to Go with 2.4 piston
    So have decided to sell the 2.2 (66 stroke ) pistons
    These are for a 2.5 engine build
    They are listed in for sale section paid $1200 posted at $850
    Thanks for all the info related to the build
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    The pistons are sold
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
