Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Rear parcel shelf trim
    Sep 2018
    Northern California
    Hi!
    I’m having a go at my targa’s interior and I’m really struggling to get the screws out of the rear parcel shelf trim! I tried with a small screwdriver but am afraid that I’m starting to strip the screw.
    I did NOT use any WD40 as I didn’t want to create a mess on the interior… Any tips would be so appreciated!
    They make small ratcheting screw drivers that take a variety of hex head bits. They operate at a 90 degree angle. I used that for mine and fooled with the bit sizes until I found a very snug fit.
    1969 911 E #824
    This type of unit works wellName:  37FF13FC-EF08-4608-AA23-C024F6D4A75B.jpg
    1969 911 E #824
    Dec 2013
    Connecticut/Florida
    [QUOTE=camarilla;1135010]Hi!
    Had the same issue on same model. Two came out...two broke off.
    1971 911S Coupe - Gemini Blue
    Sep 2018
    Northern California
    Quote Originally Posted by xpensivewino View Post
    Yep, that’s what I thought, thanks. Of course I left this tool in my storage unit… d’oh!
    From the engine compartment squirt some pbblaster into the threads, you will have to pull the insulation down to access.
    Sep 2018
    Northern California
    [QUOTE=Simonjjb;1135055]
    Quote Originally Posted by camarilla View Post
    Hi!
    Ouch. How did you end up getting those out?
    Thanks for the tip Re pb blaster - I’ll try the 90 screw driver first and see from there then…
    Dec 2013
    Connecticut/Florida
    Drilled one out successfully - but I had the rear window out. The other is still a work in progress...
    Sep 2018
    Northern California
    Quote Originally Posted by Simonjjb View Post
    Oh dear I hope it won’t come to that
    Aug 2017
    el sobrante ca.
    going from engine compartment will not get you there.
    the screws are attached to a raised bracket.
    for quick reference go to bring a trailer and pull up a Targa and look thru the posting of the cars build.
    you will see the rear parcel without upholstery.
