Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Thread: Rear parcel shelf trim
  1. #11
    Indeed, Bob is correct, I went back and looked at a picture of mine bare and the brackets are welded to the bulkhead. Sorry for the error, should have checked first.
  2. #12
    Dec 2013
    Connecticut/Florida
    If it gets really bad you can buy replacement brackets
    1971 911S Coupe - Gemini Blue
  3. #13
    Sep 2018
    Northern California
    Well, the 90 degree screwdriver worked, halfway!
    One of the screws broke off, I guess over time rust from moisture weakened the metal. The other screw stripped. I tried to use a spin it out tool to remove it but that failed as well so I just broke the top off.
    Any smart ways to get to the 2 broken screws without removing the rear glass? Given the angle I can’t get the drill bit to screw in the screw extractor
  4. #14
    Aug 2017
    el sobrante ca.
    first mask/protect the glass
    with a Dremel or die grinder grind the screws down flat
    then with a 90 degree drill the screw
    then run a tap
    have a beer
    if you can't rig up a 90-degree drill.
    there are Dremel attachments and grinding bits that you can hog out the screw enough to get a tap in and rethread
    than have two beers...........
  5. #15
    Sep 2018
    Northern California
    Quote Originally Posted by bob joyce View Post
    then run a tap
    have a beer
    Sounds lovely….
    Is it necessary to dremel the screw down before tapping? I don’t have the equipment to grind unfortunately…
  6. #16
    Dec 2010
    Southold, NY
    Are you going to use the brackets or are they for show. If the latter, glue them back in place and move on.
  7. #17
    Sep 2018
    Northern California
    “For show” but as far as I could tell they also held the rear parcel shelf in place? The bottom screws weren’t really fastening it anymore.
  8. #18
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    I would make a slot in your remaining screw with a dremel, loads of Kroil to penetrate and work the screw back in and out a few times to remove/get by the rust. You can retap easily, I did that to mine recently.
  9. #19
    Sep 2018
    Northern California
    Well the good news is I got the passenger side screw out with a vise grip. The driver side unfortunately didn’t protrude far enough and I twisted the top off so I’ll have to see if I can drill it out.Name:  E393A780-4302-4378-892F-F1F9A1A93AF0.jpg
  10. #20
    At that point the critical step is to carefully center punch the broken screw and you must be centered in the screw, then using a right angle drill motor start with small drill bits, the first small hole will show you if you are centered in the broken screw, assuming you are just keep stepping up your drill bit size until you get to the tap drill size, and if you were centered you can now tap out remaining screw bits with the correct size tap. ,,,,,Just a normal day at work.
