Thread: Door Panel Foam Strips
    Sep 2018
    Northern California
    Hi,
    I’m setting up new door panels for a 1972 targa. I stumbled upon a thread a few years ago that pointed out that the panels require the foam strips and someone was kind enough to post a link to this: https://www.amazon.com/dp/B07RP6FCKM...roduct_details
    I wasn’t able to find that thread anymore and just wanted to confirm that these are indeed a good replacement for the factory foam strips? Open to other suggestions as well
    Senior Member Bahman's Avatar
    Jan 2021
    Greensboro NC
    They are intended to eliminate rattle/noise from door panel touching the metal door frame. The tape from Amazon is of proper width and firmness. I have used it on my '72 Targa successfully.
    1972 911E Targa, Mostly Original
    2002 Porsche 996 C4 Cabriolet
    2005 Turbo-converted MINI Cooper S
    Sep 2018
    Northern California
    Quote Originally Posted by Bahman View Post
    Yep i figured as much. Don’t want to cut corners while putting the panels back!
    Thanks for confirming. The ones in my original panels are way too old for me to establish what the original height was.
    Don’t forget the moisture barrier.
    Sep 2018
    Northern California
    Yup good point. I have a set waiting to go in
