I have reorganized my collection of early Porsche parts and have several new offerings. Contact me if you see something you want or even if you are interested in a related item. I probably have it.
1. (5)3-pin CDI units 12 MO warantee-$525, with rebuildable exchange-$375.*
2. (5) Weltmeister-or equivalent gated short shifters-Porsche body(05 or 06) and custom Seine gate-$375. Add $55 for knob and $19 for new boot. Shifter alone $275.
3. (2)Carrera cooler kit ($695) coolers-(good shock mounts,short oil lines, and mounting hrdwr). Flexible AN16 Aeroquip oil cooler lines,thermostat and fittings($550)-complete front to back setup. Oil plate cooler kits-$250.
4. Mocal Oil Thermostat AOT2 -$125. AN12 fittings for Mocal-$20, AN16 -$135 SC/Carrera OilThermostat-911.107.163.OR (good threads)-$250.
5. 1970-2 911 rubber oil Lines and fittings(inquire)
6. (1)180 MPH (mechanical) Carrera rebuilt speedo-$750.
(1)2.2L 911E (70/71) $8500-$10500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(1)2.2L 911S (70/71) $10500-$12500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(1)2.0L 911E (69) $8500-$10500 Mag. Stacks/Throttle bodies etc and MFI and fuel pump
(2) 2.4L 911E (72/73) (inquire) Plastic Stacks/Throttle bodies no MFI pump
(10)2.4L 911T (72/73) $6500-$8500 Plastic stacks and MFI pump and fuel pump
8. PARTIAL MFI SYSTEMS OR PARTS eg.-injectors(6 untested $375 or
Tested $500), fuel consoles $550, MFI fuel pumps rebuilt $350-450, air boxes-$650, etc. e.g. 1972/3 2.4L 911E stacks and throttle bodies-$3500. For S-$4500.
9. (3)1972 911S oil console-$650, (5)1972 911T oil console-$425.
10. Volvo Turbo fuel pump/regulated for MFI applications(3 port direct substitute for
Bosch 001)-pressure and flow tested-$450
(3)1972 911 $350-650, (5)1966-1971 911 $450-$650(mint).
12. (1)1969-1973 Hella headlights with bezel $250, two-stage rear window switch $250.
13. 911 (1969-1973) mufflers-flowmaster (1/1)x2-($250). Bullet type (Ansa?)-$$150
14. Early fog light switches-new rubber knob and symbol $225-working light. Two stage fog light switches-$350. Cigarette lighter with rubber knob and excellent symbol $200.
15. New clutch plate for 1972 915 (225mm) $175.
16.. Early 911 jacks –good to excellent condition – used $150-175.
17. 2.4L 911S stacks (pair excellent condition)-$2450, 2.2L 911S stacks-$2250, 2.2L 911S throttle bodies-2250, 2.2L 911S 009 MFI pumps-$5000.
18. TTG 1969-73 fog lights-restored Hella TN2,4&6($425,$225&$375), Used $375-250. Fog light covers-$125 Give your car that special look. Inexpensive aftermarket fog lights $150-350. Free reproduction mounting brackets with purchases over $375
19. Good starter motors 69-73 $125—200.
20. Rebuilt (new o-rings/sealed) MFI electric fuel pumps-flow tested to spec.-$450, Carb.-$350, and CIS-$350. 914 2L Jetronic Bosch fuel pump $250. Bosch fuel pump rebuild $$325+parts+materials. Includes flow and leak test data.
21. Shift linkage cover(OEM or solid)-$75 shipped
22. Rear bumper S molding(pair) $250
23. Restoration design drivers side battery box 69-73- $185. Left and right sides $350. CONUS.
*Included are the following: pump support bracket and AL spacer, oil breather plate with cold start thermostat, oil line to pump, fuel console with bracket and filter, 6 fuel lines, 6 fuel injectors, free moving MFI pump with good pulley, throttle stacks, bodies, crossbar, and linkages, air filter housing, air filter, and snorkel, flapper box for 72/73 air intake.*
Pictures available upon request. ( X) indicates # units available.
email: pgeorge911@aol.com, Telephone 952 835-9969
