Results 1 to 7 of 7
Thread: '72 911S creaking sound under the body
    Hi, guys.
    I can hear something creaking under the back seats after replacing the spring plate bushings this summer when I drive over a step. This was my first time to replacing the spring plates by myself. When I installed the bushings, I did not put any grease on them. Might this be a cause of the creaking sound? Any thoughts?
    I appreciate your any comments or help.
    Thank you.
    Takahiro
    Did you put in rubber bushings?
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Quote Originally Posted by BOYER73S View Post
    Yes, I put in rubber bushing onto the spring plate with glue.
    Takahiro
    Aug 2017
    el sobrante ca.
    if you have checked all of your parts. then take it out on tight bumpy road and run it in....
    Quote Originally Posted by bob joyce View Post
    I drove it on tight bumpy road and heard some creaking noise coming from around the spring plates.
    Thank you
    Takahiro
    Disconnect sway bar and try again, if noise is still present disconnect shocks and try again, if noise is still present get someone to push down on rear fender while you listen underneath with a stethoscope, you should be able to pinpoint the noise source.
    Thank you for your comments.
    I will try to disconnect the sway bar first.
    Takahiro
