Thread: Antenna mount questions
    Guys
    Ready to install antenna…
    My issue is the mast can’t fit past the plastic/cable to the gas filler lid ..
    There’s not enough flex in the cable feed …..so can I just unscrew the cable end at the lid release mechanism and pull back
    to front of dash knob …..then provode a longer milky white plastic sleeve and maybe longer cable to allow the mast to raise thru fender hole ?
    Also confirming the mount for mast as a screw from inside fender thru captive nut on the mounting bracket
    As shown in photo
    Assistance is appreciated
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I have solved …..removed pull for fuel lid and installed antenna first….
    The cable to radio must be on top of latch pull setup..
    Also must inset mast/slide into bottom circular mount before inserting into under fender and extend thru fender top
    Then you can rotate the frame unit to align with attachment to back of fender hole for anchorage
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Oct 2010
    Southern Ca.
    You resolved the problem ! Now try it with the door in place , it can be done .
    Richy
    I can’t imagine doing this with door on ..
    You would need mini hands !
    And probably some invented tools
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Aug 2020
    SF Bay Area
    ...extension magnets and long needle nose pliers. worst job ever.
    - 1969 911T Ossi Blue #3981
