Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Engine 1968 Aluminum
    1968 aluminum engine.
    What you see in the picture is what is included with the engine
    This engine does not turn over.
    These early aluminum engines are bulletproof.
    The engine number is 3280352. It does not look like a standard engine stamping.
    901/14
    Build number 11887
    This might work for somebody who’s looking for aluminum case.
    We’re looking for an engine for a rolling tub.
    Thanks for looking
    Price 6,900
    Or best offer
    57B8D9E6-BE76-423A-9D4B-835F02050E46.jpg035F8BA4-F7E1-4407-A43C-984A2DDC036E.jpgB24664BE-BAC9-4CC7-BE1A-E6F65F5AEBDE.jpg3652F808-859B-4371-9FB6-2EE420D9B1E1.jpg14546695-BD2D-441C-9C71-71AE4E8C8711.jpgCF754781-CFC7-418C-B850-82267BE0EC9E.jpgC7212716-B499-4B70-B0C8-58B0ADA85E66.jpg6614B3ED-9596-45F1-84BD-F7DC478930E0.jpg
    Feb 2012
    Netherlands, Leiden
    Cool, appears to have its original ‘68 smog pump?
    That is the chain box? It only shows the smog pump pulley? You need that? I have a few
    Richard
    Feb 2012
    Netherlands, Leiden
    Ah yes you are right Richard, I didn’t look close enough.
    Bump
    Best offer
    Oct 2009
    Indiana
    To the extent that it might help the seller, isn't the 901/14 engine matched to a sportomatic transmission?
    Anyone restoring a sporto might have amplified interest.
    Otherwise, free bump.
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by DR911S View Post
    The engine number is 3280352. It does not look like a standard engine stamping. 901/14 Build number 11887
    I can believe the engine type # and the engine build #. However, the engine serial # is faked. It is not appropriate for the build #, it has no stars and it is on the wrong side of the boss.
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by mshaver51 View Post
    No, it is not.
    Oct 2010
    Southern Ca.
    Wow , the engine has definitely been re-stamped , and not by someone who knew what they were doing . The picture is not focused on the front of the boss , but it does look like there has been grinding on the front to remove the original numbers .
    It was done a long time ago that’s the way I got the engine.
    I wonder what engine numbers are close to the build Number 11887
