Thread: Front pocket positioning
    Before I cut and glue, does this look ok? Where should I end the vinyl at the top? Old VS New:
    Oct 2010
    Southern Ca.
    The front hinge bolts should be painted , so why obsess about the carpet and door pockets , but no , the vinyl is too high , why not make it like the left side as in the pictures ?
    Thanks that was my question if the drivers side had been installed correctly.I haven't cut the vinyl yet, trying to get everything in position first.
    I know the hinge bolts should be painted.
    The left were upgraded to a stronger bolt and the old ones had been done earlier and no longer match, I'll paint them all once done.
