Results 1 to 10 of 14
Thread: FS: NOS set Bosch Sport-Fanfaren or Red banjo horns
    ***SOLD***
    Bosch Sport-Fanfaren or Red banjo horns with date code 232 (December 1972) and 10.71 (October 1971) on the mounting instructions. Short or “Hoch” with reference 0 321 023 018 and Long or “Tief” with reference 0321 023 017. Nos parts in excellent condition.
    Price: 1.200 € + shipping + 6% PayPal
    May 2012
    UK
    This clearly shows these horns Nos bnib came from Bosch with the flat bracket/s integral and bolted to each horn. That is why no part number for that bracket item in the Porsche spare parts book. Confirms it is as I have commented elsewhere on a horn bracket thread by Clyde. I had intended to dig out my similar Nos sets to double-check but no need. Not intending to divert from FS thread with this post but hopefully a bump and a tidbit on spec helps the seller. Glws
    Quote Originally Posted by 911MRP View Post
    The specific bracket you are referring to is the “Befestigungshalter” with Bosch reference 1321332107 (2 required).
    There are meant to be 2 of those flat spring steel brackets per horn, the missing Porsche bracket #91163511100 is NLA but I have reproduced them as outlined in the thread Steve alludes to.
    Any car from 70 - mid 73 needs the Porsche bracket too x 1
    Strange to see 2 x NOS horns in the same box with production dates so far apart??
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Both NOS horns are stamped 232. the manual is print date 10/71
    Would help if I could read������
    Clyde Boyer
    Quote Originally Posted by dirk07 View Post
    Thank you Dirk S.! The same manufacturing dates and the same dates on the mounting instructions.
    Quote Originally Posted by TailHappyTorquelessWonder View Post
    Yes my bad����
    I have directed some Aussies to these as they need them for a special
    early 73 car
    Clyde Boyer
    Quote Originally Posted by BOYER73S View Post
    early 73 car
    Thank you!
