Thread: Wiring harness tail light
    Aug 2016
    Belgium
    The wiring harness for the tail light has 5 short wires, which are for the light unit, a mass cable with an o-fitting (which I think has to be connected to one of the bolds of the rear bumper to the body) and 3 longer wires.
    What is the use of these longer wires (on the left side of the car)?
    I believe these are for rear fog light ….mostly European
    These wires are usually bundle wrapped with tape not used for US cars
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    The Netherlands
    Rear fog light when on the left, oil tank level sender when on the right rear side mounted.
    Cees
    Oct 2010
    Southern Ca.
    I see 4 wires , 2 for the oil level sending unit and 2 for the fog light .
    maybe a universal harness, could be used for either side rather than carrying two different ones?
