Results 1 to 10 of 10
Thread: WTB: 67-68 L/H window regulator
    Member Paul Shugert's Avatar
    Feb 2015
    Prescott Az
    WTB: 65-68 L/H window regulator
    Any condition is OK; worn out gear teeth, no problem.
    I need it for 'parts'. Mainly the part that attaches to
    the bottom of the window glass rail.
    Should look like the first or middle regulator in the picture but L/H side.
    Pic only shows R/H regulators.
    BTW, Pic stolen from a old Jim Breazeale post. Thanks Jim.
    Email, text or a real phone call is all OK
    Pdshugert@sbcglobal.net
    858-735-1313
    That's all folks...
    Feb 2015
    Prescott Az
    Still looking for that L/H 65-68 window requlator.
    Any (almost any) condition is OK. Only need a single part.
    Check that stash. Easy $50 bucks.
    That's all folks...
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Paul Shugert View Post
    Hi Paul
    I can probably help you. I'll just need a break in the rain to dig one out of my stash.
    Jim
    Feb 2015
    Prescott Az
    Thanks Jim,
    Stay safe and dry.
    Heard the SF Bay area and NoCal got hit hard.
    Paul
    That's all folks...
    Feb 2015
    Prescott Az
    Still looking for that L/H regulator.
    Jim didn't have what I needed.
    That's all folks...
    Aug 2011
    north of the 49th parallel On Can.
    I have this one with the broken spring pin
    Feb 2015
    Prescott Az
    Mr Hooper,
    Thanks for your reply.
    I don't believe that one will work for the part I need.
    That one looks to be a 69-73 regulator.
    The part that attaches to the bottom window rail
    appears to be different from the earlier regulators
    in length and center attach point offset.
    Please chime in if you know for sure.
    BTW, What is your asking price?
    Someone else may need that part.
    That's all folks...
    Aug 2009
    SF Bay Area
    Mr Hooper,
    You are correct. The 2 parts will not interchange due to different measurements.
    Note 1: SWB window regulator frames are rectangular in shape. LWB window regulator frames are a trapezoid shape (the ends are not at the same angle). Now you can spot a LWB vs SWB regulator a block away.
    Note 2: LH regulators, both SWB and LWB, are 20 times more in demand than RH regualtors. (England, Australia, New Zealand, South Africa and Japan excluded)
    Jim
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Are the Targa parts the same as Coupe?
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Cliff View Post
    Yes, through 1974 and a bit further.
    Jim
