Thread: WTB: pistones rings 98 mm Mahle 95 P30,or if somebody now where to score them new
    W.T.B.pistones rings 98 mm Mahle 95 P30
    They are 98 mm Mahle pistons with high Compression reason back in the day Mahle markets them at 95 P30. Should have been more sense to call them 98 P 30?
    1,5x,1,5x,4,00 mm, or if somebody now where to score them new
    Hi did you call EBS RACING good source for rings
    Junior Member
    Oct 2018
    Vienna, Austria
    I would also try LN Engineering, they work very closely with Mahle (even supply their Nickies cylinders to them) and are very knowledgeable on aircooled engines and parts.
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Wahl should have them
