Thread: Pedal Board Fasteners?
    Apr 2011
    Central Florida
    Hello, I'm replacing the pedal board in my '71T. I have the replacement from Stoddard (which is excellent), but need to move the hardware from the old board to the new one. What kind of fasteners hold the hold down and throttle stop? They appear to be a grommet or open rivet of some kind. I've searched Bel Metric and McMaster Carr and can't find anything like them. What other options do you suggest? Thanks for the help!
    dho
    dho
    Central Florida
    Member # 1968
    I bought a bunch of those hollow rivets years ago, I think from a local company called 'Byler Rivet' but for those you also need a rivet squeezer used in the aircraft industry. I'd suggest for your single case to just use a pop rivet.
    Apr 2011
    Central Florida
    Ok, thank you, Ed. I've learned a lot from you and the other experts who share their wisdom and knowledge on this forum. I appreciate your advice.
    dho
    dho
    Central Florida
    Member # 1968
