I am in the process of taking my rear lid grill apart in order to straighten and polish it.
The black mesh grill is held w small (possible) kinda rivets. If I drill them out, how to replace them?
Any advice from experience how to proceed?
Richard
Richard
These posts have been very helpful. For future reference I keep my questions in this separate thread.
I was lucky that the first rivet separated fairly easy but the others I guess I have to drill in order not to mesh up the aluminum blades.
Question: Franz was lucky to find rivets in the sewing box from his sister but has anyone bought good replacements? I see them at several vendors but you have to buy from pictures ..
Question 2: are they black originally?
Richard
clean them and you ll see the original brass… they darken on usage and yes,
you have to buy on pics online…I do not have a reliable source for these.
the 1:1 mesh is even more delicate to find..
br
haul
59 750 pre unit triton
65 912 slate gray "erwin"
73 914 ravennagreen "ferdl"
erwin_loves_polo
I don’t think they are brass. They are silver if you remove the black.
Could it be nikkel plated?
Richard
Hey Richard,
Try here: https://lederhaus.de/nieten/
Either Doppel-Hohlnieten or Selbstlocher.
Regards,
Cees
ah…ok, you are doing a later grill?…nickel colored, assumed standard metal then
erwin_loves_polo
https://snapstools.com/collections/d...33572083433516
Is this a match with the original one?
7 mm
Common brass
Color silver
It’s a tall (20mm) grill.I will edit this later, but it might be that they are brass underneath the silver and that the ones that are black these days lost their silver?
The link Cees posted might be correct as well, but “ tails ..” is a good find. Good pictures and description.
Bottomline there are rivets out that work and I will drill out the other 15 and not risk the grill.
Btw what Franz did in a day will take me months (start to finish)
Richard
