Results 1 to 10 of 12
Thread: Option 569, protection bar between rear buffers/pads
    The Netherlands
    Hello,
    Code 569 is one of the coolest looking option available back in the day, mostly seen on UK delivered RS's. I bought recently an original 'Rammschutz' protection bar (item 104, 902.505.340.95) plus the two buffers with rubber pads (item 85, 902.505.033.095, or item 92, 911.505.029.00). I can see that 85 is for the 911 T, and 92 for S, RS (M472). Also, pretty odd that there is no one for the 911E
    Anyone know what the difference is between 85 en 92?
    I can't find the part number for the shorter rubber pad that is needed on the buffer when the protection bar is mounted, is it the same as a front rubber pad?
    One of my buffers is rusted beyond repair so looking for a replacement. Mounting holes between the regular buffer and the version for the protection are way different so might need to buy one without the holes and drill mounting holes as per original.
    Pics from the 72/73 parts manual.
    Regards,
    Cees
    Jul 2004
    Sydney, Australia
    Cees
    Suggest you search "rear nudge bar"
    (as an example) See https://www.early911sregistry.org/fo...rear+nudge+bar
    To your questions - per the above thread which has more detail (and my experience also when I fitted one to my car):
    - I drilled my own holes in the rear over-rider (or .. "buffer" ?!)
    - yes, it's the front pad that one uses on the rear over-rider
    - gasket from a 356A bumper mechanism between the chrome nudge bar and the over-rider
    Note: sadly, the gentlemen who used to re-create these bars past away some years ago.
    Paul
    1969 ex-South African RHD Tangerine 911T . 1970 ex-Southern Californian LHD Conda 911T 1955 Series 1 86" Land Rover (original Australian CKD … very slowly re-building) 1987 W124 230e
    (long term paid up member)
    The Netherlands
    Thanks Paul, that thread answered most of my questions and I can plan ahead. I have a set of re-chromed over riders, Porsche calls them buffers but unsure if I want to drill extra holes. Should not be to difficult in finding a used one that needs re-chroming, nerf bar needs it too anyway.
    Cees
    Apr 2012
    Simi Valley Ca
    When I bought my '69S, it had it had the Amco double bar on it. Pics tomorrow if anyone interested.
    Bob B
    The Netherlands
    Done some 'research' reading all the posts on the nudge bar. Interesting for sure but did not answer why the 911E did not get option 569, presume mistake in the PET. Also, difference between part 85 and 92 still unknown. May be ask Freisinger if they have those
    Front rubber pads are easy to get, nice.
    In the manual no drawing of the rubber seal between bar and bumper horn but almost everyone tells it should be there although the mount between both chromed parts is really flush.
    Found the 356 A part number: 644.505.191.00, oval seal used on the front bumper. bar There are also seals on the rear (inner and outer) bumper bars, 644.505.291.00 (oval) and 644.505.291.01 (round).
    Cees
    Jul 2003
    Santa Cruz, CA
    I’ve found the PET to have some mistakes. I’ll go back into my manuals to check availability but, i never noticed that it was not listed for the E.. The difference between the two buffers is the holes to mount the rubber trim strips. The T buffer doesn’t have the rubber strips. E and S buffers do.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    The Netherlands
    That must be it, non-hole vs holed version, good catch Michael!
    Cees
    May 2012
    UK
    I have seen differences on RHD RS with factory fitted M569 — rear protection bars with no evidence of a rubber seal between ends and chrome bumper horn (like the paper parts book) and other with a black very visibly seals protruding between. Both are lowish mileage genuine low owner — largely unmolested examples of RHD M472 RS. Hard to be sure after 50 years that they’re as originally done by factory, but I’ve good reason tk think likely are. This suggests small details of fittings used evolved with maybe one of the washers illustrated was always black (plastic/ rubber?) just what used was much larger hence protrudes quite visibly on some cars? Certainly some of those seals are much bigger diameter than illustrated — bigger than the bar.
    Steve
    Nov 2003
    Sydney
    Cees
    some pretty pics of UK RSs to keep you going . . .
    cheers
    Dennis
    S Registry member 536
    The Netherlands
    Great pics Dennis, thanks. Really like this option. Silver grey RS with two fog lights at the outside of the bumper horns is unique. Doubt it was done by the factory..
    Regards,
    Cees
