Thread: fuel hose crimping tool question
    Aug 2021
    Surrey B.C.
    I want to replace my fuel hose on the carbs. Wondering what type of crimping tool is used for the ferrules. Lots available with a huge price range. What works the best for at home use?
    thanks Jake
    mbr#4161
    69 911t
    72 2002tii
    If you're referring to the 3 " long piece between the banjos I don't think they used a crimp ferrule. It was just a sleeve that slipped over the hose ends, but was not crimped. Any crimped hose ends used a Cohlin hose crimper just for the record.
    Aug 2021
    Surrey B.C.
    thank you Ed
    mbr#4161
    69 911t
    72 2002tii
    Apr 2012
    Simi Valley Ca
    Cohline crimping tool and collars available at Belmetric. Cohline tool $2,199, Eckstein for only $1,760. Oh my!
    Bob B
    Oct 2010
    Southern Ca.
    The hose on the carburetors were not crimped but did use a collar sleeve . Brad Davis on this sight sells the exact replacement with the correct Cohline stamp , the ones from Porsche have no stamp .
    The Cohline crimper you can buy today crimps 6 sides instead of the original 8 sided crimps . The hoses are crimped on the fuel line in front of the engine .
    Thanks Richy!
    Jake, here are the caps that the factory used at the carburetor banjos.. As Richy described, they were not crimped.
    https://www.early911sregistry.org/fo...901-108-219-00
    Happy to help if you would like a set.
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
