Thread: Shout out to Ed Mayo
    I just wanted acknowledge Ed’s outstanding work at Mayo Performance. A few years ago I took my 69S heads, pistons and cylinders to Ed for inspection and a valve job. The engine had a little over 68,000 miles on it, but had sat in a barn for about 25 years. Before trying to start the engine I thought I should at least dissemble the top end for inspection and doing a top end rebuild at time seemed prudent. After inspecting everything Ed said I could just hone the cylinders and install new rings, witch I did along with him personally doing the vale job.
    Now with about another 1,500 miles on it I just did a leak down test and was amazed at the results. Four cylinders showed 0%, one showed 1/2%, and one at 1%! Thanks Ed😎
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    All of the above and a friend to any enthusiast. Helped me with info on both an electrical panel rebuild and recently with an A/C question. Wonderful giving enthusiast. Thanks Ed.
    Thumbs up
    VERY well deserved !!!
    Ed has been first in his profession, in this club, and on this board since the beginning ....
    Pics I took at the Daytona 24 Hour '2017 ... Yep, he drives his cars....
    Cheers Ed,
    cm
    Aug 2017
    el sobrante ca.
    thanks for being Ed,Ed...................
    Ed is an amazing resource!
    73 911S Targa
    He absolutely drives his cars!....one of the finest people...full stop!
