Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: What lift do you use?
  1. #21
    Jun 2011
    Mound, Louisiana
    As they say "wood is good"! I cannot count the times I have used 6x6 and 4x4 timbers to block up equipment, cars, trucks, etc.
    Very cool photo Thank you for posting that! I love the color scheme of the Martini!
    Paul Harrop 12.5% German.
    Early S #2059
  2. #22
    May 2012
    UK
    Still in use there 1974 think this is the 2.1 RSR turbo possibly the same trestle stand but single with front wheels of car on the ground
    Steve
    PS
    From a different view it seems the m491 is actually held aloft at front by a long reach high lift trolley Jack in centre of car (Jack visible behind yellow car on shot below ) — the wooden trestle is not (fully or at all?) supporting weight at front so maybe there in addition. Not sure this is safe working practice however no one appears to be under car — there appears “air” above the wooden trestle at front on the side nearest camera.
    Be safe !
  3. #23
    Mar 2017
    Orange County, CA & Tucson, AZ
    Quote Originally Posted by dummkopf View Post
    I agree. I keep several pieces of different length 4x4 timbers that I have used over the years. Work great for engine/trans drops and installs. I had a 4 post lift for years - was great for storage and it helped with some maintenance items, but the opening between the ramps was too tight for easy engine drops and suspension work also required jacking up on lift (vs 2 post lift not having to do this). I restored my car - half was done on the 4 post lift, and the other half was on the floor using jack stands and 4x4 timber.
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
  4. #24
    Jul 2008
    South Florida
    A cheap variation is stacked wooden cribs. Basically like Jenga. Lately I've noticed them on some of the car restoration shows.
    When needed steel stands do the job, but a used Rotary Lift purchased 10 years ago has been the best shop equipment expense ever.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
  5. #25
    Jun 2011
    Mound, Louisiana
    Quote Originally Posted by Bullethead View Post
    I like the car and the lift... Shop posters, etc., but I really like the boat! I have a rare 23' Howard OS raceboat with twin 245hp Mercs. I want a Donzi 29 CC so bad it hurts! LOL!!!
    Early S #2059
  6. #26
    Junior Member
    Oct 2022
    Sacramento, CA
    I use a Quickjack 7000slx. Works great on my low ceiling garage.
  7. #27
    Jun 2012
    London, Ontario, Canada
    I ise a Direct Lift 4 post. Also have the sliding jack accessory, so I can lift the car on the lift and get the wheels rotated or removed.
    Had it for 11 years. No issues. Haven’t even had to tighten anything. I check wear and level once every 6 months.
    Ravi
    Early 911S Registry # 2395
