They're fine for steel hoods due to the strength of carbon fiber.
”Lighting Resources for Hardcore Air-Cooled Porsche Enthusiasts”
Update: I replaced each hinge with OEM replacements from Porsche -- problem solved, now the hood does not stand taller that cowl with shocks installed. Someone thought that today's shocks are longer and could be bottoming out, but that's not the case. I guess wear in the hinge pivots and fatigued arms are the cause.
John Schiavone
Connecticut
Wow. Awesome.
Hi John,
Not to be an arse or anything, but... This is one of the more expensive ones. Mine came with an old boat cover. It has a thumb knob to set the height. The only thing is it is conductive. Not sure about this one, but it is surly light enough at 1.68 pounds. I bet mind will rival that!
23 1/8" collapsed, 50 5/8" extended.
https://www.amazon.com/gp/product/B0...7B8TRIYM&psc=1
Paul Harrop 12.5% German.
Early S #2059
Thank you for the info! So how much does a hood weigh? Say with the correct amount of paint? I need to go ahead and pull mine off and strip it. I know it has some filler on the leading edge and several coats of paint.
So you sources new hinges? Or had the old ones refurbished?
Early S #2059
As mentioned earlier, I use the Rennline one's that work like the 356 hood struts, and love them. My hood is steel and they have no issues holding the hood up. If the hood is up, I'm near the car and it's hands off to the people checking out the car. I've had them for a few years.
1970 Irish Green 914-6 w/2.2S
www.reSeeWorks.com
Paul
Checked out the hood strut mentioned …certainly no offense but its butt ugly
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
60 Lancia Appia Zagato GTE
I had Rennline mechanical hood shocks on my 70E. After how scary it was watching a mechanic try to shut the bonnet (even after warning the shop), I wouldn’t risk it again.
as i was building my car
I experimented with the stabilus hood shocks
they offer a regular and heavy
the heavy settles the hood higher on the cowl than the regular
