Results 1 to 8 of 8
Thread: Sunroof cables pair
    Sunroof cables pair
    I have a pair of genuine sunroof cables. They are in excellent condition.
    $245 for the pair
    $225 for the pair.
    Apr 2011
    N.Calif., south of SF
    these are used?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    They do look new but since they don't have the original packaging I would call them used.
    $200 for the pair. They are in excellent condition.
    Dec 2011
    Palm Coast, FL.
    Can you please measure these 2 areas if it is approximately 4.5mm. Thanks in advance.
    ESR # 2300
    Member sbartmess's Avatar
    Dec 2015
    NW Suburbs of Chicago
    If you're replacing early sunroof cables, which from the plastic guides I see that you are, you will have to mill down the metal guides in the same area as the plastic to fit in the channels of your early sunroof tracks. I just did it last week for mine.
    Scott Bartmess - Mbr. No. 3344
    65 356C Cab
    67 911 Sunroof
    71 914-6
    18 991.2 GT3 Touring
    Seeking Engine Case No. 911867
    Dec 2011
    Palm Coast, FL.
    Quote Originally Posted by sbartmess View Post
    It is the reason I asked because there were metal versions with the measurements like posted above that will fit the Silver tracks. It above cables are the newer ones available today it will fit the Black tracks.
    ESR # 2300
