Thread: Rennshift question after reading all the other threads
    Aug 2010
    Colorado
    Most of the other threads were done some time ago. My client sent me one to install mated to a 901 transmission. Has anyone put a lot of miles on a 901 transmission with a Rennshift? The proper adjustment with a Stromski coupler at the output shaft is about the size of the tip of a pencil. Over time and wear if anything moves at all shifting will go from good to very poor immediately. How do these things hold up over time. That said I love my stock shifter in my 67. All my clients older cars have 915's. I much prefer 901's to 915's, but that's just personal taste.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Sep 2012
    Colorado
    Chris, I put a Rennshift in my 67 911 racecar with 901. Adjustment was finicky, and in the end I switched it out for a WeVo. However, the WeVo needed modification to add a stop to prevent overtravel so on a hard shift the shift rod wouldn’t slam the transmission. Rich
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    Jul 2003
    Vienna, St. Gallen, Stuttgart
    I have a Rennshift on my 901 gearbox since 2010 / 40k km. It took a bit of adjustment at the beginning but it made the box my very favorite transmission in any car!
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Ha. I was going to say the same thing about my 901 with factory shifter. It took a bit of adjustment, but my favorite! I basically drove around for days with the panel open and a wrench. And I'd pull over and make an adjustment, one tiny spline at a time. But it truly made a difference. The shift pattern is now clear, firm, and all paths are straight and perpendicular. Through the adjustments, I definitely had times when the neutral path was not sharp and distinct, the neutral path was too short, and the forward/aft motion was angled.
    I will say though that it's probably my favorite because of the dogleg. I also love m 915 box.
    Dec 2010
    Wilmington, DE
    I have one in my 914. I just put the shifter and trans in 3rd gear, tightened the bolt and it was perfect. I have one ready for my 67 with a 915. I'll get a coupler from Stompski next time he drops by our shop. We have everything he makes.
    A part isn't purchased until paid.
    The 9 Store LLC.
