Results 1 to 10 of 18
Thread: Heat shrink tubing
    Apr 2012
    Simi Valley Ca
    Heat shrink tubing
    So, I got the double crimp tool and a bunch of German double crimp connectors from Bel Metric, now I just need some of the thick black heat shrink that the Germans used putting these cars together in the late sixties. First of all it's black, and a lot thicker than any heat shrink I have ever seen, it almost feels like rubber when you touch it. Has anyone found a vendor that sells this?
    Thanks in advance, Bob B
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by SIMI BOB View Post
    https://www.beckergmbh-online.de/search?query=7004-100 different sizes available.
    applied with a tool called dreidornzange
    Apr 2012
    Simi Valley Ca
    Thanks so much Moito, but my German isn't all that good. I only need to make 15 or 20 connections, so it would be nice to be able to just use my heat gun. Anything closer to California?
    Bob B
    Bob, I have found the Wurth to be the closest, not as rubbery but looks correct. And uses a heat gun.
    May 2013
    AUSTRIA (tu felix)
    Ed do you have a item# the assortment of würth differs from country to country....for whatever reason..the one i get from them isn`t anything close .can`t find it in the catalog
    Jul 2003
    Santa Cruz, CA
    Panduit is a supplier of all sorts of shrink tubing, with or without additional interior sealants.
    McMaster Carr, Grainger, Fastenal are go to distributors. Wouldn't surprise me if you couldn't get it through Amazon as well.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    I believe the material you're referring to is conduit, not heat shrink. Looks the same, but conduit isn't designed to contract when heated. I used to buy it from Wurth USA, at present they seem to have a very limited set of sizes available here as Art#:1771112 and 077110 (12 and 10 mm resp.). I don't know of alternatives.
    I got some shrink tubing on amazon that is marine grade (adhesive inside) and shrinks 4:1.
    I like the results because it went over the large connector end and gripped the wire end also.
    I am not home right now so I can't post a picture.
    Dean
    The tubing with sealant inside is good for electrical connections. Tight seal. Bel-Metric or McMaster Carr
    Early S Registry #235
    rgruppe #111
    Apr 2012
    Simi Valley Ca
    Thanks to all. Some good information. I too would like to know the Wurth P/N if anyone has it.
    Bob B
