Results 1 to 9 of 9
Thread: Can SWB fuel pumps be rebuilt?
    Oct 2009
    Indiana
    I bought a fresh electrical panel for my restoration. The Bendix fuel pump has failed. I also have 3 unrestored original fuel pumps.
    Is there anyone restoring Bendix fuel pumps?
    If not, does anyone know the correct Bendix model for replacement?
    Any help appreciated. Thanks in advance.
    Oct 2009
    Indiana
    Thanks!
    Do you know a professional that provides the rebuild service?
    Senior Member Cabriothusiast's Avatar
    May 2016
    Bigfork, Montana
    NO AFFILIATION EXCEPT I AM A HAPPY CUSTOMER
    https://oddparts.net/about-us/
    I have used this shop to restore 2 Hardi Fuel pumps, my gas tank and gas sending unit for my 1968 911L
    They did awesome work and I do recommend the work they did for me and the cost.
    It can't hurt to ask them about your Bendix fuel pump.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by mshaver51 View Post
    failed in which way?
    if the coil is toast it is pretty unlikely that a rebuild makes sens..since it is molded in ---
    everything else is only a question of getting the spares--- never needed spares but i also would be interested where to get them...
    are FACET pump(the bendix lookalike one) internals interchangeable with bendix?
    Jan 2007
    Phoenix, AZ
    You can cannibalize the Faucet pumps for some parts, especially the screen and gasket. I can't recall if the spring and piston work. Make sure you order the lowest pressure Faucet made if trying to use the spring and piston. I have repaired many by simply honing the piston sleeve and a light polish on the piston. Never saw one with a bad coil but I'm sure it's possible.
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by NTW View Post
    good to know--thanks much
    Indeed a new FACET pump can be a donor.
    Screen and gasket can still be bought new from Napa
