Results 1 to 10 of 10
Thread: 69 911E RPM transducer and rear fuse box wiring ?
    Hi all,
    I'm trying to make my "stop shut off solenoid" working because I have some backfiring during deceleration and I have some questions about the wiring (car is a 1969 2.0 liters).
    Here is what I found in my rear fuse box :
    On the picture there is the "other blue yellow wire not connected", this wire is coming from the RPM transducer and it should be connected to the rear fuse box on a non permanent 12V if I'm correct.
    So I disconnected the black wire that seems to go to the front of the car (rear window defrost ???) and I connected this other blue yellow wire as shown on the picture below :
    Then I started the engine , put 3000 RPM and push the micro-switch : rpm dropped immediately
    I try a second time.....no RPM drop anymore
    So it worked just one time
    Do you confirm the wiring I did is OK ?
    What happened, the RPM transducer failed ?
    Anyone who have a 2.0 liters MFI 911E who could send me a picture of his rear fuse box connections ?
    It would be great
    Junior Member
    Feb 2023
    Hamburg/Germany
    Hi,
    I was just looking for some other stuff, that I couldn't find any hint on in our German forums when I fell over your thread.
    Maybe the attached diagram will help you a little.
    I recommend looking for more details about function and testing of the RPM transducer before experimenting any more!
    Beste, Wolfgang
    wiring-diagram-69-911.pdf
    Best regards, Wolfgang
    1971 911S Coupé · Weber 40 IDA
    1973 911T Targa · Bosch MFI
    1982 911SC Coupé · Bosch K-Jetronic
    Quote Originally Posted by werinhari View Post
    Hi,
    Beste, Wolfgang
    Thanks Wolfgang,
    It is the wiring diagram I'm using.
    But as you can see there is 4 fuses on it and I have only a 3 fuses configuration.
    Junior Member
    May 2021
    CT
    This is what I’ve got
    Quote Originally Posted by Emmcee View Post
    Interesting, thanks !
    And your RPM transducer is working ?
    Junior Member
    May 2021
    CT
    Quote Originally Posted by SFE View Post
    As far as I can tell. No backfiring or idling issues, have never had a reason to do any diagnostics on it.
    Apr 2012
    Simi Valley Ca
    My relatively untouched '69S (1070) looks exactly like Emmcee's picture.
    Bob B
    Ok thanks.
    I don't have the red/black wire and that makes sense because my rear window heating is KO.
    What I see is both blue/yellow wires are connected together on a non permanent 12V spot.
    Junior Member
    Feb 2019
    Surrey UK
    Here's a photo from my 69 911E. I've got a working micro switch and I think the RPM transducer is good too but, as for the rpm dropping immediately, I can't say it does.
    Attachment 597901
