Thread: Solex dashpot/damper?
    Aug 2013
    Westlake Village, Ca.
    Looking for a dashpot/damper for my Solex’s. This one on EBay looks pretty close with some minor modifications. Anyone have any better suggestions. Thanks
    https://www.ebay.com/p/2212189690
    Scott
    303581
    The threads are too short.
    Seek:
    • Carter 202-553
    • Carter 202-552
    • Carter 202-541
    • Opel damper P/N: 8.26.924
    The pins on theses may be replaced with the pin on your OEM damper, just pull out your pin & replace pin on replacement damper using a little lube to help.
    By the way, threads are 5/16-24UNF, not metric.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Aug 2013
    Can’t seem to find those online, any suggestions on who sells those? Do you by chance know what the length that the threads should be? I don’t have the original one. Thanks
    Scott
    303581
    Ebay is your friend for these, I do not have inventory here to measure the thread length.
    I send photo of one of my restored dampers plus a scan of parts boxes that show those I have sourced along with comments regarding each. The pin on the opposite end of the threaded end may need to be shortened for some of these but that is an easy task.
    I also have a contact name in my file that may be a source for these:
    Gregory; 281.935.2401
Size:  38.3 KBName:  img756.jpg
    Paul Abbott
    Early S Member #18
    530.520.5816
    Aug 2013
    Thank you for all that great info!
    Scott
    303581
