Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Thread: early '72 oil line oddity
  1. #11
    Mar 2017
    Orange County, CA & Tucson, AZ
    Quote Originally Posted by Brad Davis View Post
    Hi Bill,
    That's right, now I remember. I am guessing the early cars used an initial version then they went to the hard line. Or maybe the T got a soft line over the transmission. Would be interesting to hear from any other 72T owners. In 68/69 the same thing happened, some hard the hard line hoop and some the soft line over the top.
    I think Beach33 may have thought the TCH fittings were out of the ordinary. Many are accustomed to seeing crimped lines these days, in reality all of the cars from mid 68 - 72 came with TCH aluminum serviceable fittings. Most cars no longer have their original TCH and replacement crimped lines are used. IMHO original lines add a huge plus to the look and soul of the car.
    It could be a T thing. My hose fittings even had matching 71 date codes on them (part of the reason I had you rebuild my line). Other than a bad paintjob, my car was very original - date codes on parts when I disassembled for restoration were all appropriate. My car also had the '71 rear fuse cover and '71 style door catch pins. This hose was most certainly the original hose to my car.
    We know Porsche used up parts - it is likely the earliest cars used up some of the '71 stock. I see the thread starter has VIN 163, mine is 228. Curious if we could identify the transition to the metal line with VIN sequencing?
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
  2. #12
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    My 7/71 911T US has a solid oil line.
    Your hose shows SAE. Never seen a SAE marked hose by factory.
  3. #13
    Mar 2017
    I wish I had better pics of my fittings, but if you zoom in on this photo you can see the 71 date codes.
    Bill
    Instagram: @myflat6
    '82SC Targa
  4. #14
    Junior Member
    Jan 2014
    North Carolina
    Quote Originally Posted by raspritz View Post
    I am curious what makes you believe this hose and arrangement is original to the car and a 'prototype'? FWIW, the hose in my '69T (2/3/69 build) runs over the bell housing.
    Hi Rich
    Using the IPM I surmised that the correct hose was the one that had the hard line running under the transmission with the crimped section of flexible hose. Seeing that mine has fittings that allowed for a full flexible hose that would support connection to the "new oil tank location" introduced in '72 led me to think prototype parts might be used. In my years of product design, we often used alternate means until suppliers were able to provide approved final sub-assemblies.
  5. #15
    Junior Member
    Jan 2014
    North Carolina
    Quote Originally Posted by dirk07 View Post
    My leaky original flexible section was replaced with the SAE Aeroquip 1503-16 line by me. The Aeroquip line was the best substitution that I could find using printed catalogs in 1995. I am sure many of the early 72's have had their hoses replaced with the assembly listed in the IPM - I was tempted but elected to keep the original style. Now I need to find the original hose and remove the SAE line.
  6. #16
    Junior Member
    Jan 2014
    North Carolina
    Quote Originally Posted by myflat6 View Post
    Hi Bill,
    Mine has two of the 90 degree fittings shown in your picture. Is there any source for replacements?
  7. #17
    Mar 2017
    Quote Originally Posted by beech33pilot View Post
    Hi Bill,
    Brad Davis (he has commented in this thread) is in my opinion the expert on oil lines. Maybe he will chime in.
    Bill
    Instagram: @myflat6
    '82SC Targa
  8. #18
    From the PET "Katalog"
    Early S Registry #235
    rgruppe #111
  9. #19
    Sep 2013
    Vancouver, WA
Size:  72.2 KBName:  PXL_20230331_003045122.jpg
  10. #20
    Sep 2013
    Vancouver, WA
    1/72 production 911T. Fittings are dated 11 /71. Been off the road since 1986. 103k original miles. I've owned it since 1993. Hardline runs under the bell housing. T coupe #1182
