Results 1 to 10 of 14
Thread: Finally got out and did my test run
    Member kent olsen's Avatar
    Sep 2010
    McMinnville, Ore
    Got my AFR installed and finally made the test run. Idle, steady 2,3,4,5000rpm I'm getting 10.7. Wide open is 13.5. As typical with webers there is still a transistion stumble about 3000 I can hold but with more/less throttle opening it goes away. F3 emulsions, 50 idle jets and 160 mains with both main and idle correction jets. Modified to 42mm by Paul Abbott. It has a special cam from Dougherty and makes 245hp @ 6900 and 230 ft/lbs at 4800rpm.
    This may seem a little rich but after playing with these webers, with help from Paul, for years it seems to be what the engine likes. I've autoxed and tracked the car for years (249,000 miles, about 20,000 on my rebuild).
    Kent Olsen
    McMinnville, OR
    72 911 upgraded 3.0L
    RGRUPPE # 104
    Sep 2010
    McMinnville, Ore
    Picture of my car
    Kent Olsen
    McMinnville, OR
    RGRUPPE # 104
    Sorry for yet another dumb question. AFR?
    Peter Kane
    '72 911S Targa
    I'm think'n it's an Air/Fuel/Ratio meter
    Hey Kent,
    I had a 3000 RPM stumble that I could not jet around but after installing a set of these air horns it went away.Name:  IMG_1690.jpg
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    May 2006
    CT
    Quote Originally Posted by 1QuickS View Post
    Hey Kent,
    Paul
    Can you tell us more about those air horns? Where did you get them and how tall/ID are they?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    https://www.dellorto.co.uk/shop/full...m-x-50mm-long/
    I spend a little time on these after I get them to improve smoothness of internal shape and to increase the inside diameter to 46mm which is the diameter at the top of all triple throat Webers. I doubt these "improvements" significantly tweak their performance. Also, if emulsion well air screens are used between the air horns then the bottom flanges need to be relieved to accept the installation of these screens: see photo of my Weber to understand this better.
    Paul Abbott
    Early S Member #18
    530.520.5816
    May 2006
    CT
    Thanks Paul
    I hate to hijack this thread, but I will anyway since this topic is likely of general interest.
    I have a 3.0 twin plug with DC 60 cams , 46 mm PMO's and 10.5 CR P&C's in my RSR Tribute car. There is a persistent stumble as the engine transitions from 3,000 to 4,000 RPM. It is almost not noticeable at partial throttle but is annoying at WOT. It has been suggested to me that I go one size smaller in venturi I could minimize the stumble at the expense of the higher end power. I have not tried this but your post on these air horns has me wondering if they might be worth a try.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Sep 2010
    McMinnville, Ore
    Hey Paul I remember seeing those the last time I was over to see you. Are they something you are selling? If so send me a text and mayhaps I'll get some. Oh can K&N filters fit over them??
    Kent Olsen
    McMinnville, OR
    RGRUPPE # 104
    Hi Tom,
    PM sent
    Paul Abbott
    Early S Member #18
    530.520.5816
