Would love to see some pics of the car as it stands. Good luck with your endeavor!
Peter Kane
'72 911S Targa
I think Chris is spot on...
My last restoration - 2018-2023 to take a 1971 911T and make a very close representation of a 1973 RSR with RSR brakes, RSR trailing arms, 3.0 high butterfly MFI, etc... not a perfect recreation, that wasn't the intent, but close enough... In fact the extras I wanted added to the cost... touring interior, and electric AC... It took 5 years and cost more than 300k euros... I did none of the work, but was very involved throughout the process - and have restored many in the past, so was very particular about certain things - panel gaps, all Porsche parts where possible... We also explored restoring a very solid 1971 S to stock, and came up with around 200k euros if we didn't need to source any parts that were missing... e.g. MFI parts, etc...
I kept a spreadsheet that lists every part and part number categorised like the Porsche Parts Book, and separate out Labor for other categories - like disassembly, body work, paint, plating, etc...
first ride - 10 yrs old in a 73 911S - Silver - I was done for
Started 'playing' with them in the late 80s
Started racing a 72 911 T built to 2.9L RSR in SoCal SCCA, PCA, POC early 90s
Have owned over 50 long hoods from late 80s until 2000
dropped out from 2000 - 2018 - due to life, work, travel
Been building a 2.8 'RSR' inspired car since 2018 - 9111121235
http://forums.pelicanparts.com/porsc...1121235-a.html
It does sound like labor/hour is much more in the US than in Europe (here usually $100/hr for specialist shops, more for Porsche dealership). My Targa was restored for around $70k plus $25k engine and while not perfect in details, it's holding up well. It took around a year and I thought that was a long time. LOL
Bottom line, you're not ever going to end up on top financially. Buy a finished car.
1970 2.2S Elfenbeinweiss
2002 996 TT Midnight Blue
Member #3833
Like everyone else has said, it depends greatly on what you want the end result to be. If you're looking for a decent driver you can do things for far less than if you're looking for show quality, paint, bodywork and interior. Personally I prefer my cars be driver quality so I can drive them anywhere and not be afraid. My rule is never to have a dog or a car you're afraid of, I have Chihuahua's and driver cars as a result.
If you can let us know what you're end result will look like we can give you a more detailed info on costs. People can say, "I paid X for this level of paint and body", etc.
---Adam
Check out Unobtanium-Inc.com
New blog posts all the time!
Three major elements will define the cost of a restoration:
- mechanical situation: engine rebuilds start at 10K, but can go up to 50K (if you want almost every part which shows wear and tear to be replaced by genuine parts. For 10K younwould get a mechanic (who knows the engine) to diassemble the engine, clean the parts, gets the parts back straight, change the seals and reassemble it. When parts are not reaworkable, costs will go up. Eg. Original cylinders at Porsche cost 1K each at Porsche.
- body workre-1977 cars have no HDG plates. So bare metal is only protected by the coated applied at the factory. Over the years, ware gets in almost any whole, which makes it rusting from inside to the outside. Even original cars kept in storage for 60 years, are prone to rust. The problem mostly is that you only see it when you start to remove the paint. Many cars also had major or minor bodywork repairs in hte past decades, whe repair techniques were not tha current level 25 years ago. What recently started as an easy repaint on my car ended in a bare metal respray, after discovering several weak (rust spots) in the sheet metal. We spent about 700 hours, just for removing paint and coatins, de-rusting, welding wholes, grinding and fattening the metal. No signs of rust or wholes were visbile when we started the job…
- finishing: while removing a lot of parts and trim, you will find parts in bad shape, which will need replacement or repair. Fr other parts, you have to decide whethe you can live with signs of age and usage, but the bill for spar parts can easily go up i, the 1000s.
Even going for a less then concourse result, with a tired engine to work upon, I can only confirm that minimum 50K needs to ne foressen if you want to get the car to a mechanic to bring the engine at acceptable performance and to have a re-spray with a minimum replacement of spare pars
As the previous writer said. “These cars rust from the inside out.” I can’t tell you how many cars I’ve seen bought by VERY knowledgeable Porsche folks. The cars appear to be solid from the outside and just need a paint job. Once the paint is removed repairs done when these were just $10 to $15000 old cars are revealed. One thing leads to the next and soon the whole car is apart. The challenge now is anything not restored sticks out like a sore thumb. After observing this and working on these cars my idea of a PPI has been greatly expanded. All lights and turn signals need to come off. A digital probe in the rockers, heater tubes, torsion tube, and on a SWB car, through the battery box and across the hollow part of the front pan. Unfortunately the owner isn’t going to let you or me take the engine compartment pad off or the interior off below the rear windows. Or take out all the windows. Rust turns a happy buyer into a “How did I get myself into this fix.”
A complete engine build with new parts is dirt cheap compared to derusting one of these cars and repainting.
1970 Irish Green 914-6 w/2.2S
www.reSeeWorks.com
My car seemed solid and with nice paint but when I started really poking around I found a lot of Bondo and patches. Right now I’m in for $93K on just the metal work at a well known specialist. They’ll be doing the paint also and I’ll do the rest. I’m hoping the total costs will stay under $200K when all is done. Good shops in metro areas are now getting between $150 to $200 per hour. It adds up quickly!
Hopefully, your car will only need a minimal amount of metal work.
The original poster of this thread has not even been on this site since they posted this question accordingly to their profile
Scott
303581
maybe he was allergic to zeros
Probably suffering from sticker shock as the numbers quoted above are real.
