Results 1 to 2 of 2
Thread: SWB drivers side tail light issue
    Aug 2010
    Colorado
    I can get a bright brake light or I can get a bright bulb when I turn on the lights. When using both the driver side duel filament bulb illuminates less. I have LED's. I went back to the stock bulb. Same results. I've cleaned the ground and bulb holders. I've grounded the lights with a separate wire. I've switched the tail light housing to the passenger side and it worked fine. The housing is VERY clean. No rust. Any ideas?
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
