Thread: WTB: 1970-1973 fuel charcoal carbon canister bracket
    Hi everyone,
    I am looking for the bracket that holds the charcoal carbon canister on North Americans 911 from 1970-1973. The bracket is bolted on the front trunk floor in between the fuel tank and the left battery.
    Original part number is: 911 201 071 00
    Ideally a good condition one!
    Thanks for your help.
    Photos are not mine but only for reference purposes.
    Still looking, if you have the canister with it, that is even better!
    I believe this is the correct canister…
    https://www.ebay.com/itm/155553089493
    Peter Kane
    '72 911S Targa
    Thank you for the link, it is a shame I don't look more frequently. It is good to know some VW have shared the same part though I will look for these too!
    Dec 2003
    West Los Angeles
    The steel part of the bracket is easiest to find, but the rubber strap is almost always broken or cracked and close to breaking. You can buy an SWB battery hold down strap, cut it short and rivet it to the steel bracket and you'll be good to go.
    techweenie.com
