Results 1 to 2 of 2
Thread: 2.2E pistons and 006 distributor
    Member RockhillMtr's Avatar
    Apr 2023
    Tomball, TX
    Set of 84mm 2.2E pistons, all measure within spec according to the factory manual. Some minor scuffing on two of them, but not enough to deem them unusable. They are pretty stained and ugly looking but it’s cosmetic. Pins have staining but no pitting. With a light polish probably be fine. Have clips. Certainly not perfect but might be good for a budget build.
    $300 plus PP fees and shipping
    006 2.2E distributor as you can see disassembled for cleaning/rebuild. Everything is there. Only the thin phenolic slip plate is no good. Full rebuild kits are now available for this distributor. Shaft play is negligible. This distributor has the exact same advance curve as the 007 “S” , only difference is the RPM limit on the rotor.
    $350 plus PP fees and shipping.
    Apr 2023
    Tomball, TX
    Open to offers
