Results 1 to 2 of 2
Thread: Radio Installation
    Junior Member
    Jun 2023
    Radio Installation
    I have a Blaupunkt Karlsruhe radio and would like to swap out the current vintage 1990’s AudioVox pull out radio. (For a “so called” pull out there must be a trick or missing key.). However, I believe this was a radio delete until the Audio Vox was installed. Hence, I am concerned that the DIN and support bracket is not appropriate for the more correct Blaupunkt.
    Oct 2010
    Southern Ca.
    I would be concerned also , so you may need to obtain the correct bracket , clips and faceplate . Not always easy , the dealers did not always instal these correctly when the cars were new .
