Results 1 to 8 of 8
Thread: 1973/75 RSR console for MFI Pump
    Aug 2007
    Phila Pa. area
    The RSR uses a platform to mount the MFI pump, just like the street cars use. However the RSR version uses rubber bushings ,meal washers, and 3 small metal tubes to isolate vibrations . Does anyone know where to get thw rubber bushings etc.
    Mike.
    Mike
    I built some for an ST using air pump hardware, everything needed to be cut to fit.
    Aug 2007
    Phila Pa. area
    Gled49
    What air pump, from what model Porsche . Do you have the part number for the rubber bushings and the washers ?
    Mike
    Mike
    75-79 USA 911 smog air pump. I’ll look for numbers.
    May 2014
    Finland
    Looks very similar with Mercedes 190SL Alternator bushing that is available as a kit. It has M8 bolt size.
    https://www.sls-hh-shop.de/main/de/m...r/109109-p--12
    911 1965 MY66
    911E 1972 Coupe
    911TV 1973.5 Coupe
    I saved all the bags and part numbers but not sure of quantity or modifications. It’s obvious when u build it, what the objective is. One issue is getting the console as low as possible. Not sure if all the parts listed were used or not. Also don’t know current availability.
    Aug 2007
    Phila Pa. area
    Gled49
    Thanks for the info and the part numbers, should make construction a lot easier. Also do you have any 92mm cylinders and pistons? Trying to complete a broken set. Thanks again.
    Mike Curnow
    Mike
    I don’t have any 92mm stuff.
