Thread: Change o-ring in the mag carter bolt
    Hi, I need to change an oil ring in the magnesium carter of one of the bolts close to the oil radiator (see picture) ... I am worried that by loosing the nut to replace it I will somehow compromise the whole tightening of the carter ... any thought / advice?
    Massimo
    Instagram
    Twitter
    Go ahead, if its leaking now, which I assume is why you're doing this, you'll either fix it or it will still leak, and you'll be no worse off than you are now.
    Many thanks Ed, going to follow your advice
    Instagram
    Twitter
