Thread: advice on removing lower engine latch
    Aug 2020
    SF Bay Area
    For some reason I have been stymied by the removing the engine lower catch plate. I have tried rotating and tilting it many different ways and it just doesn't quite clear the slot to come out.
    I swear I had it out before, but I'll be damned if I can remove it now.
    Any advice or tricks welcome. Thanks in advance.
    - 1969 911T Ossi Blue #3981
    Aug 2020
    Shawnee, OK
    Took mine out 6 months ago. Just disconnected the cable, removed the two bolts and do not remember any difficulty getting the lower latch out. Any chance of damage that could have made the opening smaller?
    Steve
    Aug 2017
    el sobrante ca.
    i know what you are talking about
    just go back to it and try again
    it will happen
    i vaguely remember dipping it down and then out
    Aug 2020
    SF Bay Area
    Quote Originally Posted by 1969911T View Post
    Steve
    Certainly possible. Feels like the factory schutz on the back engine wall is just enough to keep it from clearing the gap.
    Aug 2020
    SF Bay Area
    Quote Originally Posted by bob joyce View Post
    it will happen
    Good advice. It is so close but not quite and feels like a brain teaser. Will try again.
    Aug 2020
    SF Bay Area
    Bob was right. I returned to it a few days later and it took a little pressure here and there to get it out. Putting it back in required a 45 degree turn and it dropped right in.
    Thx
